Line lock fittings?
Old Jul 18, 2003 | 06:15 PM
gojo's Avatar
gojo
Default Line lock fittings?
I have been given two part #'s for the adapter fittings.
Weatherhead #7974 and # 7936. Which fitting # is correct? Any one know?
Old Jul 18, 2003 | 07:17 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Line lock fittings? (jfpilla)
7974 is the correct # for a 12mm to 3/8 adapter.
Some other brands
ADAPTER STANDARD TO METRIC BUBBLE
Edelmann #265000
Everco #3014
Weatherhead #7974
Female Inverted Flare Seat 3/16" (3/8-24 thread)
Male Bubble Flare 12-1.0MM
:cheers:
Old Jul 18, 2003 | 10:28 PM
gojo's Avatar
gojo
Default Re: Line lock fittings? (Flyin'Brian)
Thanks. That's a big help.
Old Jul 22, 2003 | 09:02 PM
gojo's Avatar
gojo
Brian,
Reading a bunch of posts about the line lock can scare the heck out of you. Thanks again for the help, it was easy getting the parts.
I took the line lock to Napa. They matched a 3/16 line with fittings to the unit. They provided the fittings with seats to seat the brake lines to the line lock unit. I only had to tell them that I needed the 7974 adapter.
Here are the NAPA #'s and quantity needed for an 03' C5.
2 #202 x 3 fittings
1 #813-1202 and 813-1205 ( 30" and 8"line)
2 #7974 adapter fittings
1 2517 tube bender
1 10 pack(only need 1 for ground) connector #784285
Total $18.35 includes tube bender
[Modified by jfpilla, 12:10 PM 7/23/2003]
To Line lock fittings?
