BF Goodrich KD's
Old Jul 19, 2003 | 01:09 AM
Z06Plasticfantastic's Avatar
Z06Plasticfantastic
Default BF Goodrich KD's
Anyone try these tires on their C5 or Z06? If so, what was your experience?
I am running stock F1 Supercars and looking for a stickier tire but want more wearability than Hoosier's. Will use the tire for club events and high speed time trials. Daily driving and wet weather traction is not a concern, I'll drive something else.
Stock F1 sizes currently, 295-35-18's in rear, 265-45-17. Want to run about the same size using existing 18-10.5 rear and 17-9.5 front rims. I believe the KD's are available in the same sizes, however the front is a 275-slightly taller and wider but apparently within the acceptable variance ratio/range to not be problematic with the traction control.
Appreciate any thoughts or comments.
thanks
Old Jul 19, 2003 | 01:16 AM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: BF Goodrich KD's (Z06Plasticfantastic)
Oh ya!!!
Incredible sticky dry weather tire. Have them in 295's and I wouldn't trade them for any brand of 315. Check out DJSELF also running an LPE TT (650hp+) and he uses them on the Track. Also, MATTG, who has a 436 ci Stroker and who road races constantly has gone through 3 sets. Once you get them, you'll never try anything else. Just be careful in the rain.
[Modified by MARK's_C5TT, 1:17 AM 7/19/2003]
Old Jul 19, 2003 | 01:58 AM
XmentalPilot's Avatar
XmentalPilot
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Default Re: BF Goodrich KD's (MARK's_C5TT)
I am running 295-35/18's and 275-40/17's... you'll have no problems with these on the stock Z06 sized wheels. These are an amazing tire. Done two track dates and use them on the street... they are holding up very well.
Probably the best dry traction out there. :thumbs:
Old Jul 19, 2003 | 02:11 AM
bandit_99's Avatar
bandit_99
Default Re: BF Goodrich KD's (XmentalPilot)
Don't want to hijack the thread, but I was thinking about these tires too: I was planning on putting these on my stock rims (non-Z06). Would you recommend the stock size or go larger and if so, how much bigger? I know firestones are pretty narrow, but don't know much about the BFs.
Also, are these G-force KDW? I looked on tire rack and these are all that were available.
From all I've heard, these are great for drag racing, but what about every day use...or how about the twisties? I've got Pilot sports and they stick in the turns pretty well, but they suck for 60'. I
Thanks. :flag
[Modified by bandit_99, 1:13 AM 7/19/2003]
Old Jul 19, 2003 | 08:57 AM
GR8-LIFE's Avatar
GR8-LIFE
Default Re: BF Goodrich KD's (bandit_99)
Don't want to hijack the thread, but I was thinking about these tires too: I was planning on putting these on my stock rims (non-Z06). Would you recommend the stock size or go larger.
I have 18 x 11 HRE's and the 295's are perfect. But before I got the HRE's, I had reuglar stock with the same KD's and they hung over the lip just a tad but no big deal. If you get chance, go with 18 x 11 as the tire will look better and you'll have options of getting the BFG 315 DR. Unfortuntely, BFG (Michellin) has no plans of making the KD's in size 315.
Never ever confuse the KD's with the KDW's.
The KD's are best when it comes to cornering
Thanks. :flag
[Modified by MARK's_C5TT, 8:59 AM 7/19/2003]
Old Jul 19, 2003 | 10:02 AM
bandit_99's Avatar
bandit_99
Thanks Mark- That's exactly the info I needed. :thumbs:
Old Jul 20, 2003 | 04:02 AM
Z06Plasticfantastic
Thanks for everyone's input. Tire Rack or Discount Tire next. Any other good places to buy these?
Old Jul 20, 2003 | 07:53 AM
GR8-LIFE's Avatar
GR8-LIFE
There use to be a Discount Tire rep on the CF - I think his name was Todd???
He gave me a real good deal on 18/265 KD's for my front. Noone else could match the price. Every now DT also has incredible discounts on these for some reason. Next time I see a pair of rears I'll grab 'em.
Old Jul 20, 2003 | 03:02 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
If you are intersted I have a set of 285-30-18's for sale. They are wider then my 295 DR by aboutan inch. Let me know. kaley
Old Jul 20, 2003 | 11:35 PM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Bandit.
Don't get these confused with KDWs! The tire you want that is the subject of this thread are the BFG KDs (Not the kdws)!
These tires i have always heard rock for dry weather (only) traction and these are what i will switch to when my stock z06 supercar tires are toast! :smash:
Old Jul 21, 2003 | 12:14 AM
COBrien's Avatar
COBrien
Cruise-In III Veteran
St. Jude Donor '06-'07-'08
Default Re: BF Goodrich KD's (MTI 427 Roadster)
The KD's are awesome...best tire I've ever had on any car!!
Old Jul 21, 2003 | 01:06 AM
Shag Finger's Avatar
Shag Finger
OK couple of questions here, on my GTP I run the KDWS all season tires and amd able to get 2.0 60's which is down right amazing for a street tire on a 350HP FWD car. My best on DRs was a high 1.9 and that was even matched with a set of RE-730s. So I know that the Ge-Force line of tires do perform well. What I am wondering is how well the KD and or KDW tires perform on the 60's and if anyone has any experience with the Bridgestone S-03s or even the S-02s at the drag strip. My goal as it has been with every car is to be as fast as I can on my every day street tires, but to make sure that I get the absolute stickiest street tire that I can short of getting drag radials.
Old Jul 21, 2003 | 10:43 AM
bandit_99's Avatar
bandit_99
Bandit.
Got it. Thanks for the input, I won't mix them up. You shouldn't have too many problems burning up those supercar tires. :crazy: :D
To BF Goodrich KD's
