Vararam Install Help Needed....
Old Jul 19, 2003 | 11:20 AM
chuckster's Avatar
chuckster
Default Vararam Install Help Needed....
Ok I feel stupid.
I had to replace my radiator shroud with a new one because I had the Vortex.
Anyway, The new shroud did not come with the 2 white push clip retainers on each side.
Is there a trick to get these off without destroying them?
All the EASY intuitive steps are clearly documented with pictures. Big deal. I need info on the stuff like (Remove the Fog lights and Factory Air Deflectors) huh?
Air deflector? you mean front brake cooling duct?
Now I know this must be painfully obvious..But.. How the hell do I get the original fog light scoops out??
The inside bolts are easy to reach.. But the outside I cannot even see..
The front brake cooling duct is in the way and I don't see how to easily slide it out?
Man I pride myself on figuring out stuff..but I need help. :conehead
Old Jul 19, 2003 | 11:40 AM
chuckster's Avatar
chuckster
Default Re: Vararam Install Help Needed.... (chuckster)
Never Nind... :rolleyes: I just needed to manhandle that Cooling duct to pull it out.. I was just afraid to distort it too much...
All out and fully accessible.. :smash:
Old Jul 19, 2003 | 05:09 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
5:10 pm. you done yet? :jester How hard was the job? Have you driven it yet? Can you compare it to the Vortex? :reddevil
Bob
Old Jul 19, 2003 | 07:50 PM
chuckster's Avatar
chuckster
Default Re: Vararam Install Help Needed.... (16Again)
Bob
I have not finished yet.. I had to stop for a 98 years birthday party.. ;)
I will try to finish up more tonight and tomorrow..
I will tell you this is a tedious job..Not hard just tedious.. The fact that my garage is 93 degrees inside is not helping..
Old Jul 19, 2003 | 09:49 PM
Jim Terry's Avatar
Jim Terry
St. Jude Contributor
Cruise-In III Veteran
The Vararam site has installation pictures that show what parts have to be removed. I left the brake ducts in place and just worked around them. What I found about the fog lights was remove the 10mm bolt holding the whole assembly on, not the screws holding the fog lights in the holders. I messed with that for hours! Like anything, once you've done it once, it all makes sense. Good luck with it! :seeya
Old Jul 19, 2003 | 09:50 PM
PeteyPete's Avatar
PeteyPete
Default Re: Vararam Install Help Needed.... (Jim Terry)
Let us know how it turns out...and how the car feels after your done! :)
To Vararam Install Help Needed....
