Had to redesign the Vararam
I got to thinking how thin the plastic is here and it should be reinforced with something thicker than 1/16" plastic. I mean the hole sits like 1/8" inch from the edge..
Here is a pic of the damage
These strips are the same material as the Vararam. I will use ABS GLue to adhere these to the rear side of the flange. This strip is at least 2 to 3 times thicker.
Here are the 1/8" ABS reinforcing strips next to the V Plate. One these are glued on I will drill them out using the existing holes for a template
Patrick if you read this..I'd be more than happy to explain what happened.
I can't wait to get it all buttoned up.. :smash:
[Modified by chuckster, 9:59 PM 7/19/2003]
[Modified by chuckster, 10:01 PM 7/19/2003]
But it's pretty obvious that the plastic is too thin to handle any pulling..
Let me know how it works out.
