Installed COH CL Bypass Pull Key Wait 10 Sec. Message
Old Jul 20, 2003 | 01:46 PM
Harris's Avatar
Harris
Default Installed COH CL Bypass Pull Key Wait 10 Sec. Message
Installed Corvettes of Houston column lock bypass kit. Got the pull key wait 10 seconds message. Pulled key, waited, everything seems ok now. Anything to be concerned about?
[Modified by Harris, 5:45 PM 7/20/2003]
Old Jul 20, 2003 | 02:01 PM
jmX's Avatar
jmX
Default Re: Installed COH CL Bypass Pull Key Wait 10 Sec. Message (Harris)
If it just happened the first time, I wouldnt worry about it. If it happens again, that would be strange however.
Old Jul 20, 2003 | 02:57 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Installed COH CL Bypass Pull Key Wait 10 Sec. Message (jmX)
:iagree: should have no error messages....probably nothing..if it happens again might wanna give them a call
Old Jul 20, 2003 | 05:44 PM
Harris's Avatar
Harris
Kinda what I was thinking, thanks!
Old Jul 20, 2003 | 10:11 PM
jmX's Avatar
jmX
Guys, the way Column lock bypasses work, its like 1 bit of memory. It can be off or on. Now, when you first hook it up, the car is expecting a certain value by default. If COH forgot to "set" the bit before they shipped it, the first time you use it, it'll set the bit properly and from that point on, it will work flawlessly. The only downside to it is you'll get the pull key msg the very first time.
So, if it only happens that very first time, there is absolutly nothing to worry about. Its like a lightswitch and they just forgot to switch it on before they sent it.
Jon
http://www.ls1howto.com
To Installed COH CL Bypass Pull Key Wait 10 Sec. Message
