Getrag 3.42 diff....Will it leak?
Old Jul 24, 2003 | 09:18 PM
RJ's 002's Avatar
RJ's 002
Default Getrag 3.42 diff....Will it leak?
Differential leaks are well documented on this forum. I have a 2.73 right now that is dripping, dealer has not fixed, and I'm thinking about the 3.42 gears anyway. I'd replace it with the Getrag, which obviously is the same mfg as the stock rear end
Will I have any better luck with the 3.42 staying dry? Any one had a leaky modified rear end?
Old Jul 24, 2003 | 09:42 PM
Buckmaster's Avatar
Buckmaster
Cruise-In III Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04
Default Re: Getrag 3.42 diff....Will it leak? (RJ's 002)
I have 3.42's and no leaks!
Old Jul 24, 2003 | 10:23 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Getrag 3.42 diff....Will it leak? (Buckmaster)
i changed my 2.73's to getrag 3.42's six months ago with no leaks. good luck. :cheers:
Old Jul 24, 2003 | 11:25 PM
Roadfrog's Avatar
Roadfrog
Yes, it will / can leak. It's a Corvette.
The voice of experience here.....
Old Jul 24, 2003 | 11:26 PM
TDP's Avatar
TDP
Getrag is the manufacturer for ALL C5 differentials, regardless of the gear ratio. :)
Old Jul 25, 2003 | 05:24 AM
irfgt's Avatar
irfgt
Default Re: Getrag 3.42 diff....Will it leak? (TDP)
Having just experienced the leak situation, if I were going to replace a rear end, I would remove both side covers and apply a bead of Permatex Grey RTV sealer tp both covers prior to installation. This will probably cure your potential leaks.
Old Jul 25, 2003 | 07:52 AM
Pat97Vette's Avatar
Pat97Vette
The differential has a plate rivetted to it that says GET RAG - this explains it all. :lol: :lol: :lol:
Old Jul 25, 2003 | 08:03 AM
Purerock105's Avatar
Purerock105
I had 2.73's for 60k miles that didn't leak once. I replaced them with
the 3.42's and 10k miles later...no leaking. Remember with these cars
you're not just replacing the ring & pinion, but the entire assembly.
Still, even if properly installed, they can still leak. Usually they don't.
...and are you sure it's the rear-end, and not the tranny. It's in the
rear as well. Replacing the gears would certainly give you ample
opportunity to check everything once, twice over for leaks.
:cheers:
Old Jul 25, 2003 | 11:13 AM
Mike Mercury's Avatar
Mike Mercury
Default Re: Getrag 3.42 diff....Will it leak? (Purerock105)
let me clarify that...
Getrag is the manufacturer for ALL C5 differential cases, and only the 2.73, 3.15, 3.42, and 3.73 gear sets.
The 3.90 and 4.10 gear sets are not manufactured by Getrag.
Old Jul 25, 2003 | 01:16 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
I've have a 3.42 Getrag on my A4 for almost 3 years---no leaks yet :) However, it's pretty well documented, as per the many threads on this forum, there is a possibily any ratio Getrag may (has) leaked. This would not keep me from getting rid of that 2.73 "slug" gear and installing a 3.42. Good luck, what ever you decide to do. :seeya
Old Jul 25, 2003 | 01:20 PM
Special K's Avatar
Special K
Mine leaked at the drain plug. Fixed it with plummers tape on the threads.
Bob
:flag
Old Jul 26, 2003 | 02:21 AM
MY1Fast99C5's Avatar
MY1Fast99C5
Default Re: Getrag 3.42 diff....Will it leak? (Korreck)
I am using 3.42s and after many hard 1.58 60' launches I dont have any leaks. :smash:
Old Jul 26, 2003 | 11:41 AM
Mike Mercury
Default Re: Getrag 3.42 diff....Will it leak? (MY1Fast99C5)
:cool:
I envy you guy.
To Getrag 3.42 diff....Will it leak?
