Non Pop-Up Headlights
Old Jul 25, 2003 | 08:25 AM
VinnyG's Avatar
VinnyG
Default Non Pop-Up Headlights
Has anyone installed a set of these? How difficult, worth the money, etc.???
Bring that custom modern look to your C5 with this great new non-popup headlight system. No longer will your lights be a speed brake for night driving. The brackets that come with this kit are made out of 60-61 aircraft aluminum with DOT approved low beams mounted using a bubble level for adjustment. High beams are CATS performance lights. Headlight tubs come unpainted, but primed and ready to paint to match. Cover is a tough Acrylic molded lens. Kit include a heat and moisture reduction fan system. The installation is very easy, everything comes "pre-mounted". You will need about 20 minutes to remove your original headlights, and about 1 hour to 2 hours to install your new headlights giving an original and aggressive look to your C5. Low beam wattage is total of 160 watts and high beam is a total of 360 watts. For the ULTIMATE in night time driving, add a Philips 9006 HID (High Intensity Discharge) lighting system which is also available and custom made by us.
LA-NONPOPUP-SC$1,189.95
[IMG][/IMG]
[Modified by VinnyG, 5:26 AM 7/25/2003]
Old Jul 25, 2003 | 05:20 PM
rfgoss1's Avatar
rfgoss1
Default Re: Non Pop-Up Headlights (VinnyG)
Hi Vinny
Are you a new supporting vendor of the forum?
Rg
