BBK TB
Old Jul 27, 2003 | 01:27 PM
ITSovr4U's Avatar
ITSovr4U
Default BBK TB
Will adding this mod to my car change my A/F ratio and screw up my tunning. I have a 346 with H/C and every other bolt-on. It had 427 RWHP on the dyno. Will i gain anything with this mod or will it hurt me. I am using the stock TB now. Thanks in advance. JOHN :seeya
Old Jul 27, 2003 | 02:03 PM
Brian@KelleyPerf's Avatar
Brian@KelleyPerf
Default Re: BBK TB (ITSovr4U)
Hello John.. From what I have seen, if you replace your stock TB with a larger unit, you will definately change your A/F ratio and hence your tuning. Whether your engine can benifit from a larger TB is debatable. Given that you are running a stock displacement and are already putting down some great numbers, I would say leave good enough alone!! :)
