2002 ECM?
Old Jul 27, 2003 | 06:27 PM
split63's Avatar
split63
Default 2002 ECM?
For 2002, is the ECM for the Vette and the Camaro/Firebird the same?
Thanks,
[Modified by split63, 3:27 PM 7/27/2003]
Old Jul 27, 2003 | 11:12 PM
mapman's Avatar
mapman
Default Re: 2002 ECM? (split63)
For 2002, is the ECM for the Vette and the Camaro/Firebird the same? .....
ECM? Do you mean PCM (Powertrain Control Module) or EBCM (Electronic Brake Control Module)?
Probably easiest just to ask the local Chevy dealer's parts department.
Old Jul 28, 2003 | 12:20 AM
split63's Avatar
split63
Default Re: 2002 ECM? (mapman)
THe Electronic Control Module (ECM) that controls the ignition timing, and Fuel injection system of the Engine
Old Jul 28, 2003 | 01:02 AM
mapman's Avatar
mapman
The PCM handles that function in the Corvette. It interfaces with many of the other computers on the C5, Automatic/Manual Transmissions, HVAC, Cruise Control, Theft Deterrent, Anti-Lock Brakes, turns on/off the generator, etc. I would guess that the cars are different enough that the ECMs/PCMs are not compatible. Your Chevy dealer should be able to give you a definitive answer.
Old Jul 28, 2003 | 03:01 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Same phsical PCM, different software calibration. It would have to be flashed with correct calibration to be functional. I tried to start a C5 with the f-body PCM and the drive by wire throttle control would not function.
To 2002 ECM?
