Tech 2 ????
Old Jul 27, 2003 | 11:11 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Tech 2 ????
What are the advantages of using a Tech 2 over Autotap, Ease or EFILive????
Old Jul 27, 2003 | 11:55 PM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
Default Re: Tech 2 ???? (binksZ06)
Couldnt tell ya...but I love the Tech 2. It's all I've ever used.
Old Jul 28, 2003 | 12:18 AM
Brian@KelleyPerf's Avatar
Brian@KelleyPerf
There are many advantages over using the other items you mentioned. Look below for the positives:
Positives:
1: Doesn't require a laptop or computer to run.
2: Doesn't have to go through a "boot" mode to load an O/S like a computer does.
3: Doesn't "lock up" like a computer does!!
4: You can turn on and off different paramaters and even flash the PCM with GM calibrations.
5:Very intuitive and easy to use.
Dissadvantages:
1: COST!!!! A new Tech2 is over 2K!!!
I'm sure others will chime in but the above is what I can think about off the top...
Old Jul 28, 2003 | 05:50 AM
SFVetteman's Avatar
SFVetteman
Default Re: Tech 2 ???? (Brian@KelleyPerf)
It is an excellent diagnostic tool that together with the service manual allows you to diagnose virtually every system in the car, not just the engine.
In addition, it will work on other GM cars as well from about 1993.
Old Jul 28, 2003 | 06:14 PM
irfgt's Avatar
irfgt
Default Re: Tech 2 ???? (SFVetteman)
That puppy is about $5500.00
Old Jul 28, 2003 | 08:11 PM
SFVetteman's Avatar
SFVetteman
Default Re: Tech 2 ???? (irfgt)
I bought mine used for $1400 but I've seen them new for $3000. Still not cheap but a lot less than $5500.
To Tech 2 ????
