A/F ratio
Old Jul 30, 2003 | 03:33 PM
ITSovr4U's Avatar
ITSovr4U
Default A/F ratio
Can somebody please post a dyno sheet with the lambda #'s of a H/C 346. I would like to compare them to mine, I would post mine but have no way of doing so. My A/F ratios go up and down an awful lot through out the rpm range is this normal. Thanks in advance, John :cheers:
Old Jul 31, 2003 | 12:11 AM
JamMasterJ's Avatar
JamMasterJ
St. Jude Donor '06
Default Re: A/F ratio (ITSovr4U)
Your car is way to slow for you to be concerned about such things. :seeya
Old Jul 31, 2003 | 12:49 AM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
I usually tune a flat 12.9:1 - 13.0:1 AFR across the entire powerband.
Old Jul 31, 2003 | 03:47 PM
ITSovr4U's Avatar
ITSovr4U
Default Re: A/F ratio (Godspeed)
My A/F ratio is 12.1 at 2000rpm and between 2800rpm and 3500rpm it gradually rises to 12.6 and then gradually back down between 3600 and 5000rpm to 12.2 and from 5000rpm to 6500 it goes up from 12.2 to 13.1. The car really pulls in the higher rpm range, Is this car tuned right. :banghead: :banghead: Thanks , JOHN
Old Jul 31, 2003 | 04:08 PM
ITSovr4U's Avatar
ITSovr4U
Default Re: A/F ratio (JamMasterJ)
That is awful funny coming from a guy who wants to get his tank to beat me. You should just fill that thing with goldfish, And make it a fish tank. :yesnod: :lol: See you at the track on the 6th. :sleep: :mad
Old Jul 31, 2003 | 07:12 PM
JamMasterJ's Avatar
JamMasterJ
St. Jude Donor '06
Your right about the tank thing, but I prefer blue fish. Perhaps if I replace my current floor boards, dashboard, body panels and tires with Balsa wood it would help. I'm convinced its all the wax you have on that queen that makes it glide through the air, so perhaps all I need now to leave you behind is some of that wax...
... and that balsa wood thing. :nonod: :lurk:
Keep it up and I'll let Cartek know your "competitors" cobbed up, home made package is outpacing me, and I'm sure they would step up to the plate...
:nopity $$
Old Aug 1, 2003 | 04:54 AM
ITSovr4U's Avatar
ITSovr4U
ttt :skep:
Old Aug 2, 2003 | 01:16 PM
ITSovr4U's Avatar
ITSovr4U
ttt :seeya
To A/F ratio
