Right now, my car has the LS6 cam and intake, tpis headers, offroad xpipe, 3500 yank stall with 2.5 str, and a vararam. Oh, and a tranny cooler and shift kit.
Anyhow, I ran consistent 7.80's and 12.20's at the track friday on Nitto's.
I have a TNT f2 kit that I'm going to install next week.
My car has the 3.15 gears now and I was wondering if going to 3.42's or 3.73's will help alot. If they'd only be good for a couple tenth's in the 1/4, then I don't want to spend the extra money on gears when I could add a fuel pump and injectors and just spray 150 instead of 100.
Re: How much would gears help my current setup? (xSSv)
Both would give you about 2 tenths maybe 3 but go with 3.90 and you could see a 5tenth drop and 3 or 4 mph gain. :thumbs: I run 3.42s but they seem to work well with my yank 4000 conv.
Re: How much would gears help my current setup? (LittleBoyBlu99)
How bad would traction be with that steep of gear? Right now, the nitto's hold well to consistant 1.75-1.77 60ft times. I have some 17" et streets on back order. I'm hoping they get here soon because I think with the spray, the nitto's are going to get blazed. :D
You are right with a 150 shot you will probably have traction issues with your Nitto's. If I were you I would think twice about spraying a 150 shot if you are running the stock bottom end.
Re: How much would gears help my current setup? (MC98)
:withstupid: Get the gears and run a 100 or 125 shot, many say 150 is safe, but many say it isn't and why push the limit on a multi $K motor.
