Anyone know or have an estimate of how much fluid the clutch will take after a good bleed? Thanks!
Hydraulic Clutch Fluid P/N 12345347 or equivalent DOT-3 brake fluid, can't be more than a couple of cans. :)
I don't see an amount for brake fluid or clutch fluid in the service manual, I guess there is no way to tell how much will be lost in the bleeding process.
I use some DOT4 brake fluid ATE amber 200 or even valvoline syntec works fine. After you get it bled remove the fluid from the reservoir once a month, wipe it out with a lint free paper towel and refill it. More often if your car is taken to the track.
