@#$%'ing leaking battery - Not GM this time...
Old Aug 3, 2003 | 11:56 PM
Trey395's Avatar
Trey395
Default @#$%'ing leaking battery - Not GM this time...
Back in March I managed to kill my battery after draining it to nothing. (left the radar plugged in all week) Picked up a new one from NTB, which was supposed to be top-of-the-line. Well, this weekend I was installing some gauges and noticed drops of what I thought was oil on top of the battery. (figured I had spilled a little bit last change)
Nope! Upon closer inspection the battery had cracked at the top and was dropping down the back. I mixed up some baking soda and water and sprayed it down as completely as I could. Doesn't look like it got into the PCM, but might have hit the wiring harness. So far, so good though. I'm just going to keep an eye on it.
NTB did replace my battery without any hassle, so I have to give them credit for that...
Old Aug 4, 2003 | 01:41 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: @#$%'ing leaking battery - Not GM this time... (Trey395)
glad everything is ok.
next time try the ACDelco AGM battery. 78P7YR. #19002255.
Old Aug 4, 2003 | 01:49 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Re: @#$%'ing leaking battery - Not GM this time... (ROCKnROLL)
try nothing else but Optima Yellow top or Red top ... no acid to leak :D
Old Aug 4, 2003 | 08:02 PM
molon labe's Avatar
molon labe
Default Re: @#$%'ing leaking battery - Not GM this time... (mike76002)
:withstupid:
i got a bunch of electronics in the car, so i went yellow top. definitely worth the extra $.
Old Aug 4, 2003 | 08:14 PM
Greg_E's Avatar
Greg_E
I can't find the link, but I'm sure I read that GM was having some problems with the AGM batteries as well. I don't think it was a problem with them leaking but problems none the less.
Old Aug 5, 2003 | 01:28 AM
PaceThis's Avatar
PaceThis
Default Re: @#$%'ing leaking battery - Not GM this time... (Greg_E)
OPTIMA!
Old Aug 5, 2003 | 01:54 AM
qs_zo6's Avatar
qs_zo6
Default Re: @#$%'ing leaking battery - Not GM this time... (PaceThis)
OPTIMA!
:yesnod:
Old Aug 5, 2003 | 08:32 AM
Tom/99's Avatar
Tom/99
It dosen't seem like batteries are being made as good as they were years ago. The Delco battery, in my 1985 Oldsmobile will be 10 years old next month.
Old Aug 5, 2003 | 08:36 AM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
:iagree:
Old Aug 5, 2003 | 01:16 PM
Trey395's Avatar
Trey395
Default Re: @#$%'ing leaking battery - Not GM this time... (JR_VETTE)
I tried to get a Optima Yellow top as a replacement, but they didn't have any in stock. All they had was a blue top? which I think is a marine battery.
Didn't want to try experimenting with that...
Old Aug 5, 2003 | 01:17 PM
Wadoka's Avatar
Wadoka
Cruise-In 1-2-3-4-5 Veteran
What chain stores and outlets sell Optima batteries? And do the Champion batteries that have the same case as an Optima rate about the same?
~Matt
Old Aug 5, 2003 | 01:20 PM
Trey395's Avatar
Trey395
Default Re: @#$%'ing leaking battery - Not GM this time... (Matt Black)
NTB is going to be stocking them, Sears just started...
Old Aug 5, 2003 | 02:41 PM
molon labe's Avatar
molon labe
talk to James at KC Trends. he'll hook you up.
Old Aug 5, 2003 | 03:01 PM
sbkim's Avatar
sbkim
Autozone has them. I picked up red top and they suck! My voltage reads very low each time I start in morning. I am thinking about upgrading to yellow top.
Old Aug 5, 2003 | 03:42 PM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
Cruise-In VI Veteran
Never had a problem with SEARS Diehard's. :yesnod: I have yet to hear of anyone having any leak problems with them as well.....great warranty on them too! :thumbs:
Old Aug 5, 2003 | 06:02 PM
LS7's Avatar
LS7
Screw GM and their battery. :U
Get the Optima Redtop or Yellowtop. :thumbs:
Old Aug 5, 2003 | 06:08 PM
molon labe's Avatar
molon labe
Default Re: @#$%'ing leaking battery - Not GM this time... (sbkim)
wierd. maybe you got a dud. i think they have a 2 or 3 yr warranty. take it back at 3 am and heave it through the window of autozone.
Old Aug 6, 2003 | 10:23 AM
sbkim's Avatar
sbkim
Default Re: @#$%'ing leaking battery - Not GM this time... (tattooed)
done.
let's meet up for dinner etc Thr nite.
Old Aug 6, 2003 | 12:21 PM
molon labe's Avatar
molon labe
done.
definitely! we have a couple of the BIG VPs in the office this week, so i'm going to need to par-tay after they leave on thursday. :)
To @#$%'ing leaking battery - Not GM this time...
