Manual Transmission Fluid
Old Aug 6, 2003 | 02:57 AM
Jochen's Avatar
Jochen
Default Re: Manual Transmission Fluid (luvinc5)
:iagree: I think as long as you stay with a "good major brand" of synthetic ATF you will have improoved shifting. Some people swear "Redline" others Amsoil or Mobil1.
I changed 6 months ago to Mobil1 and do feel smoother shifting. No more hazzle getting into first gear after stoping the car in neutral.
Jochen
Old Aug 6, 2003 | 03:40 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Re: Manual Transmission Fluid (RobsC5)
How does one change the fluid? Is it hard?
:iagree: Does anyone have a write up for us that don't have service manuals?
You will need a 3/8 square socket and a jack. The tranny has a fill and a drain plug, so make sure the fill plug will loosen before you drain the fluid and find out you can't get the new in. You'll also need a pump of some type to get the new fluid into the fill opening. I'm sorry I don't have pictures but once you get the car up in the air there is an orange sticker on the tranny that says " use dexron only" or similiar words.
Old Aug 6, 2003 | 05:16 PM
gmblack3's Avatar
gmblack3
Default Re: Manual Transmission Fluid (Mark 84ltblu)
http://www.woosch.com/tranny_diff_fluid_change.htm
