Non-Run Flats
I have been sitting here for the past few days, :banghead: trying to reason why I require run flats on my Vette. Run flats seem to offer only one feature that is worthwhile, and that is the ability to drive 50-200 miles with zero-pressure in the tire (mileage varies with tire manufacturer). However, there seems to be overwhelming reasons not to purchase a run flat, and these are:
Not that many places that will dismount or mount a run flat, either due to archaic equipment or non-knowledgeable operators of said equipment. (Called 12 places in and around Nashville and found only few places that would mess with run-flats. Out of those that would, one charged a hefty premium to repair a run flat tire.)
You can carry a 12-volt compressor, a good set of reliable plugs (I do mean reliable), and even a small scissor jack, and plug your own tires on the side of the road, if you should pick up a nail. (Gloves, and a heavy duty paper coverall to wear is optional, but not a bad idea.)
I have not had a normal flat in over 10 years. (Normal defined as a flat caused by a sharp object that penetrates the tire in the tread area. I have had a few destroyed tires caused by giant potholes when living in MI, and I am not sure if a run-flat would have lived through these potholes anyway; sidewalls were split). In addition, please do not mention Murphy’s Law; :nono: I understand the implications of Murphy Law, and fully expect to get at least one flat in a set of non-run flats if I decide to purchase a set. :yesnod:
Good quality new tires are not likely to “blow-out,” but are more likely to pick up a nail and slowly lose pressure. Keeping the air pressure sensors, and checking the air pressure daily (as I already do), would give an indication that you have picked up a nail. At which point you can add some air and go to the nearest tire store, or if in the middle of nowhere, plug your own and continue on your trip. (Those people you see on the side of the road with blowouts usually have driven the tire with low-pressure, in high ambient temperatures, causing the tire to flex beyond design specifications, creating too much heat, and boom goes the tire. The others on the side of the road were driving on tires where you could see the air inside as easily as the air outside…better known as bald tires…and they should not have been allowed to drive on them in the first place.)
If you need to plug your tire in the middle of nowhere, you can plug your own tire, then you will have a better chance of finding a place to dismount a non-run flat and patch/plug the tire, versus having a run flat correctly repaired.
Better ride, no more bouncing over raised expansion joints, better cornering, and no hydroplaning (considering the new Goodyear F1). (Raised expansion joints are really not a problem in TN, but if I travel to MI to visit, they become a large problem.)
Less expensive.
Reasons for run flats:
If you pick up a nail, you can continue to drive until you find a place that will work on a non-run flat tire.
Is my reasoning correct, :crazy: or am I full of crap? :bs
[Modified by WhiteC5Vette, 5:43 PM 8/4/2003]
Decision made, Goodyear Eagle F1 GS-D3s ordered and will be installed by Aug. 16, 2003.
[Modified by WhiteC5Vette, 7:41 PM 8/12/2003]
Ditch the runflats, you'll be very happy.
About the F1's though (assuming you mean the OEM Z06 F1 supercar tire) I seem to recall they actually have a poor reputation for hydroplaning and wet performace. The GS-D3's would be the tire to look into if you want to stay with Goodyear.
:cheers:
My biggest reason to just pump it up and go is that it is unsafe to spend a lot of time fixing a flat by the side of the road with cars whizzing by at supersonic speeds. Even with Run Flats, I carry an air compressor, plug kit, and 2 X 2 patch if the puncture is on the side of the tire. Nail flats are not a problem but hitting something in the road can damage the side of the tire requiring road service. So I say call somebody.
No, I don't think I will put another set of run flats on our Vette. I would look very close at Kumho, Yokohama, and Bridgestone for my next set of tires. You are right about the ride on run flats, it is awful.
I say get a good set of tire and enjoy the ride!
:cheers:
I got rid of my run flats and replaced them with Bridgestone SO3s. Quieter and better wet traction. I've got an air pump and plug kit. But anytime somebody asks me what I'm going to do if I have a flat, I just say: "I've got a cell phone and a AAA card!"
:cheers:
:cheers:
I have my road service via my insurance company so I can call any tow truck, pay the fee, and submit to TN Farm Bureau for reimbursement.
As for bad neighborhoods, I always have twenty-one close friends with me to help in situations that might arise in bad neighborhoods. :jester
Think I'll go ahead and order a set of the Goodyear F1 D3-G3s in about two weeks.
(Locally they want a fortune for these tires, two Goodyear stores quoted me $1250.00, mounted and balanced, another Goodyear store told me it was illegal not to use run flats, and it would also void my warranty. Can't print here what I told him as I slammed the phone in his ear. Gateway tire will mount and balance each tire for $20.00, and with shipping from Tire Rack a complete set will cost $960.06.)
I'll take the risk of the odd-chance catostrophic flat in exchange for a smooth, quiet, grippy wet & dry set of tires at 1/2 the cost every day!
:D :D :D
I couldn't agree more. Well said!
But if you decide not to have it you can't bitch when you need it.
Your flat will ocurr late one evening out in the boonies, maybe with a sweet one riding shotgun. Murphy will see to that.
Like the man said "do you feel lucky?"
The "sweet one" can change the tire, while I hold the flashlight, and if that occurs, I won't get lucky. :lolg:
for weight savings.
I wonder what the first vehicle that came with EMT's was...? :crazy:
