steering column noise
Old Aug 6, 2003 | 12:23 AM
sutl-huh's Avatar
sutl-huh
Default steering column noise
has anyone experienced a creaking sound comimg from the steering column during low speed turns?
Old Aug 6, 2003 | 04:00 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: steering column noise (sutl-huh)
Can you try and explain the creek noise better? Where does it come from, front, back....
Old Aug 6, 2003 | 04:24 AM
Face's Avatar
Face
I get the same thing right after the car is started, it's worse when it's cold or humid outside. After driving for a few minutes it disapears. I've been told it was the "boot". There's a piece of styrafoam inside it that's rubbing. But I've also read it was a plastic bushing that needs to be lubricated. Either way it's bothering me and I need to fix it soon.
Old Aug 6, 2003 | 04:33 AM
pkmoose's Avatar
pkmoose
Default Re: steering column noise (Face)
Hi Face :seeya
Old Aug 6, 2003 | 01:03 PM
Torqued84's Avatar
Torqued84
Default Re: steering column noise (pkmoose)
My 2000 had a squeaking noise when I bought it a couple of months ago. Dealer said it was a sensor in the steering column needed replaced. Would have been about $500 if not under warranty.
Old Aug 6, 2003 | 01:04 PM
Torqued84's Avatar
Torqued84
C5 Squeaking steering fix link from Tech Tips https://www.corvetteforum.com/techti...D=35&TopicID=1
Old Aug 6, 2003 | 01:13 PM
sutl-huh's Avatar
sutl-huh
Default Re: steering column noise (Torqued84)
Thanks for the help. I really appreciate you taking the time to answer my questions :thumbs:
To steering column noise
