Column Lock
Old Aug 6, 2003 | 03:50 PM
Yoggi's Avatar
Yoggi
Default Column Lock
I have been reading about the column lock problems. I just bought a 1999 vert. 23K miles. Seems perfect.
However, I just checked my sterring wheel and it does not seem to be locked at all. Could it have been modified not to lock or is this also a probelm with the column?
Old Aug 6, 2003 | 03:57 PM
Crispyc21's Avatar
Crispyc21
Default Re: Column Lock (Yoggi)
If it does not lock at all then either the Column lock bypass has been installed or your car had the correct 'fix' done. You're good to go!!
[Modified by Crispyc21, 3:57 PM 8/6/2003]
Old Aug 6, 2003 | 04:09 PM
C5JONNY's Avatar
C5JONNY
Default Re: Column Lock (Crispyc21)
:iagree: If you can turn the wheel with the key out of the ignition, you should be fine. ;)
Old Aug 6, 2003 | 04:13 PM
Yoggi's Avatar
Yoggi
Default Re: Column Lock (C5JONNY)
Thanks for the feedback.
I can turn the wheel with the key out of the ignition. So I guess the previous owner had the fix put in.
Thanks again.
Old Aug 6, 2003 | 04:34 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
:yesnod: Your are in good shape IF you can turn the wheel w/o the key in the ignition :)
Old Aug 6, 2003 | 04:47 PM
jmX's Avatar
jmX
Default Re: Column Lock (BiggieBoy)
The wheel will always turn a little...the lock wont engage until you turn it a fair amount...maybe 10-20 degrees of rotation, so make sure you are turning it enough.
As others have said, if it doesn't lock, there's either a bypass installed or the dealer removed the locking pin. :)
Jon
http://www.ls1howto.com
To Column Lock
