Wandering coolant temperature
Old Aug 7, 2003 | 08:33 AM
splinters's Avatar
splinters
Default Wandering coolant temperature
Recently had the water pump replaced on my 1999 coupe (leaking). After the replacement, the coolant temp has gone as high as 230^ when the car is at idle. When you are going 35 mph or higher, the temperature usually stays at the prescribed 190^. Had one dealer check it out and they said everything was normal. All fans are coming on. I don't remember ever seeing the temperature rise this high before. Any ideas?
Old Aug 7, 2003 | 09:36 AM
C6~Missle's Avatar
C6~Missle
Default Re: Wandering coolant temperature (splinters)
Sounds normal.. The fans come on about 227 or close to that.. So it sounds like all is well.
mike
Old Aug 7, 2003 | 09:59 AM
c5chris's Avatar
c5chris
That's normal, seen those temps when the car's T-stat was stock. You can force the fans to come on earlier if you turn on the A/C.
What you should do is change the thermostat and make the fans kick in earlier either by a manual fan controller or via programming.
Old Aug 7, 2003 | 10:38 PM
TXSTICK's Avatar
TXSTICK
Default Re: Wandering coolant temperature (c5chris)
If you ran it low on water and hot, you might need to replace the TSTAT.
Could be sticking abit.
Does it seem to take longer for the car to warm up in the morning?
[Modified by TXSTICK, 7:39 PM 8/7/2003]
Old Aug 8, 2003 | 10:06 AM
splinters's Avatar
splinters
Default Re: Wandering coolant temperature (TXSTICK)
No, it warms right up and was not run with low coolant.
Old Aug 8, 2003 | 10:52 AM
mozart's Avatar
mozart
Its acting just like its suppose to.and seems normal. I think if its different than before your pump change what you were seeing then was abnormal if it was different cause your right in line with correct cooling temps now and it appears your fan is working properly. :)
To Wandering coolant temperature
