CAGS bypass
Old Aug 7, 2003 | 10:46 AM
splinters's Avatar
splinters
Default CAGS bypass
Installed CAGS in 99 coupe. First one ordered gave "check engine" light immediately after install. First replacement had wrong size plugs. Second replacement lasted 3 months, then "check engine" light popped up. Any similar experiences?
Old Aug 7, 2003 | 11:01 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: CAGS bypass (splinters)
nope, mine worked fine with no issues.
Old Aug 7, 2003 | 11:04 AM
jngoldin's Avatar
jngoldin
I have had the CAGS installed for over 18 months (= age of car) with no problems. :confused: I haven't heard about anyone else having this problem. If the CAGS-device you are using has the wrong resistance you would get the symptoms you describe. I believe it should be 2.2 Ohm. The "wrong size plug" remark makes me suspect you have the wrong product for the car. Who did you buy it from?
Old Aug 7, 2003 | 11:05 AM
Patches's Avatar
Patches
I had the standard store-bought CAGS elim. that worked fine for almost the last 2 years. I recently pulled it and did the CAGS through LS1 Edit which also eliminates the indicator on the dash.
:cheers:
Old Aug 7, 2003 | 12:16 PM
Michaeljh2000's Avatar
Michaeljh2000
The cags eliminator is nothing more than a 1/4 watt resistor meant to trick the computer. Instead of paying $20, I used used a 5 cent resistor I had laying around. Taped it up real good. That was over a year ago. No problems.
Old Aug 8, 2003 | 10:01 AM
stogiepuffer's Avatar
stogiepuffer
Put mine on over a year ago. Tried to start the car and it wouldn't even turn over. Took the cables off the battery, waited a few minutes and hooked them back up. Haven't had a problem since. Good luck!!
Old Aug 8, 2003 | 10:04 AM
splinters's Avatar
splinters
Default Re: CAGS bypass (jngoldin)
It was purchased from Mid-America.
Old Aug 8, 2003 | 10:30 AM
add's Avatar
add
What is CAGS?
Old Aug 8, 2003 | 05:38 PM
MSIP's Avatar
MSIP
Default Re: CAGS bypass (add)
CAGS = "Computer Aided Gear Selection", or some such horse pookie. It makes a 6-speed into a four speed under certain conditions.
To meet Corporate Average Fuel Economy (CAFE) regulations, Chevrolet figured out that after your car warms up, and you shift out of first at low RPMs, you could "force" the driver to shift from first to fourth and it would improve fuel economy. If you always rev it up, CAGS should never kick in. But the CAFE testers follow a set procedure, so CAGS raised the fuel economy for Corvettes, which is good (for GM) but VERY annoying. CAGS works by engaging a relay that forces the shifter from 1-4. The relay has some resistance, and if you simply unplug it, you get "codes on your DIC." Sounds like a personal problem, huh? Anyway, the clean way to do this is to plug in a resistor into the cord after you disconnect CAGS to fool the system into thinking it is working. No 1-4 shift and no codes.
Buy a CAGS defeater from a supporting vendor, or if you are adventurous (like me), search for +CAGS +"radio shack" on the web and you will find out how to spend $.99 (for 5 resistors, but you only need one) and you can do it yourself.
Hope this helps...
To CAGS bypass
