Which Cam should I use?
Old Aug 7, 2003 | 08:46 PM
corvette_karl's Avatar
corvette_karl
Default Which Cam should I use?
I have the MTI Stage I (that's one) heads, the MTI True Ram Air Induction kit, and TPIS Headers. It's also a 6 speed.
I want the car to pull from mid-rpm's on up, and don't want just a top end car, even if I sacrifice a few hp's at redline . . .
Anyone have any suggestions on which cam I should use, and why? I'll probably get the cam and kit from MTI . . .
Thanks!
Karl
Old Aug 7, 2003 | 08:56 PM
SFVetteman's Avatar
SFVetteman
Default Re: Which Cam should I use? (corvette_karl)
Since you have MTI heads and want to go with a MTI cam, you should probably talk to them as they should know what cam would match up best with your heads to give you the characteristics that you want.
Old Aug 8, 2003 | 01:53 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Which Cam should I use? (SFVetteman)
:iagree:
Old Aug 8, 2003 | 02:19 AM
Barely Legal's Avatar
Barely Legal
Default Re: Which Cam should I use? (pkmoose)
A B1 or TR220 will work nice with those heads.
To Which Cam should I use?
