engine check light
Old Aug 10, 2003 | 06:25 PM
myron's Avatar
myron
Default engine check light
The pos post on bat. leaking. I change the batt. I used baking soda& water to clean acid.I installed a new batt. THE ENGINE CHECK light stayes on.I remove for batt 1/2 hour light goes off.About 10 miles light comes on.
I went to local dealer for 3 dayes.They change the secondary air ing pump
cores ok no 20wgmpc.drove home the light is back on again
Can some on help
myron :cuss :chevy
Old Aug 10, 2003 | 09:14 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Re: engine check light (myron)
according to the owners manual if the light is on steady, an emission control system malfunction has been detected.
have you checked for any codes?
Old Aug 10, 2003 | 09:22 PM
Xssesive's Avatar
Xssesive
Default Re: engine check light (ROCKnROLL)
You need to clear any existing codes go to https://www.corvetteforum.com/techti...D=25&TopicID=1 I know when I replaced my battery computer acted up and through some codes, but after clearing them everything was fine.
[Modified by Xssesive, 8:23 PM 8/10/2003]
Old Aug 10, 2003 | 10:20 PM
IMQUIK's Avatar
IMQUIK
I cleared codes for a buddy 2day & he has a check engine lite on the way home????? He also just changed to a new battery....hmmmm?? :confused: WTF? :confused:
Old Aug 10, 2003 | 10:33 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: engine check light (IMQUIK)
what codes are coming up.
To engine check light
