Rear Wheel Clicking?
Old Aug 11, 2003 | 10:06 AM
wkasak_07Z06's Avatar
wkasak_07Z06
Default Rear Wheel Clicking?
I know this is a stretch to identify a noise without actually hearing it, however, here's the description:
Passenger Side Rear Wheel...clicking noice consistant with increase in speed(mph), clicking becomes faster...doesn't matter if trans is in 1,2,3,4,N. I'm thinking possibility of wheel bearing. Car is Out of Warrenty, so any opinions would be appreciated.
:cheers:
[Modified by wkasak_98Coupe, 10:06 AM 8/11/2003]
Old Aug 11, 2003 | 10:08 AM
Sweet98's Avatar
Sweet98
Default Re: Rear Wheel Clicking? (wkasak_98Coupe)
Ive heard a faint clicking on my 84, but only when the roads were silent and i was going slow... never figured it out
Old Aug 11, 2003 | 10:41 AM
C6~Missle's Avatar
C6~Missle
Default Re: Rear Wheel Clicking? (Sweet98)
Did you make sure there was nothing stuck in the tread? Best to check the simple things first.
mike
Old Aug 11, 2003 | 11:06 AM
wkasak_07Z06
Default Re: Rear Wheel Clicking? (C5~Missle)
mike
That came to mind right after posting, and I went out and did a quick check and didn't see anything. I will get it jacked up tonight for a more detailed inspection. I have non-runflats, and the tires has not lost any pressure lately...
Old Aug 11, 2003 | 11:50 AM
SAXN8R's Avatar
SAXN8R
mike
:iagree:
Most likely the head of a nail or a rock stuck in the tread, but it could be something else. Check it out and let us know what you find.
Old Aug 11, 2003 | 12:31 PM
blue98coupe's Avatar
blue98coupe
Default Re: Rear Wheel Clicking? (SAXN8R)
try jacking the car up and run the wheels slowly ,if you dont hear the clicking then it most likely is the half shaft .I had the same noise going on jacked the car up and could not hear it click but when a load was on the rear then click click click .I swapped the wheel bearing and guess what click click click swapped the half shaft and no more noise .Good luck :cheers:
Old Aug 11, 2003 | 12:41 PM
Richin Chicago's Avatar
Richin Chicago
:cheers:
If it is a wheel bearing the tone the intensity will, usually, vary from changing lanes (varying side loading) Clicking is usually more associated with a cracked rotor making contact with the pad on a high spot. Also a loose spline clicking only occurs when you first start in motion or let off of the gas quickly and then back onto the gas but it isn't constant. At least theses are my experiences.
Old Aug 11, 2003 | 12:43 PM
wkasak_07Z06
Default Re: Rear Wheel Clicking? (blue98coupe)
Does the half shaft have bearings as part of it, or are the bearings seperate and replaceable? Anyone have pictures from the shop manuals (I know time to buy a set :p: )?
How much does a new half shaft w/all bearings etc. cost?
Thanks in advance.
Old Aug 11, 2003 | 12:51 PM
wkasak_07Z06
Default Re: Rear Wheel Clicking? (Richin Chicago)
Wow..great info. From your description, it doesn't sound like a wheel bearing. It's definitely just a click...click...click..click..click.clic k.clickclickclick
I will pull the wheel and check for cracks in the rotor tonight also.
The spline you talk about would be a part of the half shalf? Correct?
Thanks.
To Rear Wheel Clicking?
