Lowering my car
Old Aug 12, 2003 | 10:34 AM
02MillenniumVette's Avatar
02MillenniumVette
Default Lowering my car
Has anyone used the lowering kit from Mid America? Here is the link. http://www.madvet.com/shop?store=1&c...y=148&frame=79 If you have used it, is it easy to install and does it lower the whole car and not just the front or back? If you have any other suggestions, I would like to hear them. Thanks in advance.
Old Aug 12, 2003 | 10:40 AM
Net Exploit's Avatar
Net Exploit
Default Re: Lowering my car (02MillenniumVette)
I just ordered one of the Forum. It is a GP. Looks the same. I think what you have is for the rear, considering I only see two bolts. Same as what I ordered. Front is low enough for me.
Hope this helps,
Dan
:cheers:
Old Aug 12, 2003 | 11:06 AM
THRAP 42's Avatar
THRAP 42
Save your money. By using just the stock bolts alone you can drop the entire car 1.25 to 1.5 inches, my front air dam is only 2 inches off the ground.
If you go much lower you'll be brakeing for every road kill you come across - right now I just watch out for possums and truck tire tread.
later,
Old Aug 12, 2003 | 11:13 AM
Busa196's Avatar
Busa196
Default Re: Lowering my car (THRAP 42)
later,
:iagree: This is what I did, and my car is loooowwww. 26" in the front and 26.5 " in the rear...from the ground to the center of the fender well. Best looking mod I've done yet, IMO. :thumbs:
Old Aug 12, 2003 | 12:49 PM
02MillenniumVette
later,
Cool. Are there any tech articles on how to do that? All I want to lower it is about 1 inch. Thanks.
Old Aug 12, 2003 | 01:07 PM
too-ntenz's Avatar
too-ntenz
This subject interested me too. I also would like to learn about how to do this. Can anyone point us in the right direction for instructions?
Thank you in advance for your reply
~Bob
:thumbs:
Old Aug 12, 2003 | 01:20 PM
Nelson V.'s Avatar
Nelson V.
Default Re: Lowering my car (too-ntenz)
There's instructions for doing this under Tools>>Tech Tips>>C5
I finally did it this w/e and it was very easy. With air tools and all the hand tools ready, it took a little over an hour, front and back.
One thing to note that wasn't in the tech tip: Maybe this only applies to F45 cars, but I found it easier to turn the front bolts if I first unbolted the lower end of the front shocks.
And one thing to note about the results: I went as low as I could all the way around. Although the ride is still bearable, it is somewhat reminiscent of my Neuspeed-fitted Corrado - translated: bumpy. It's not too bad, but I am going to leave this way for a couple weeks. Then I might consider raising it back up just a tad if I can't get used to it.
[Modified by NelsonV98Vert, 10:21 AM 8/12/2003]
Old Aug 12, 2003 | 01:23 PM
Nelson V.'s Avatar
Nelson V.
Default Re: Lowering my car (My question)
Now that I've done this, do I need to get a wheel alignment?
I haven't noticed any difference in steering, handling, pulling, etc.
To Lowering my car
