CAGS bypass failure
Old Aug 12, 2003 | 03:06 PM
splinters's Avatar
splinters
Default CAGS bypass failure
Found the reason for the CAGS bypass failure in my 99 coupe. The resistor was fried. Purchased from Mid America. Does anyone know the actual Ohm value of the resistor so I can replace it? Mine was burned enough to render the color bands unreadable.
[Modified by splinters, 8:21 PM 8/12/2003]
Old Aug 12, 2003 | 03:22 PM
minivette's Avatar
minivette
Default Re: CAGS bypass failure (splinters)
Nevermind, that's what happens when you are busy at work and try to respond to a post. :crazy: When I saw "bypass" I thought you were referring to the "column lock bypass".
[Modified by minivette, 5:39 PM 8/12/2003]
Old Aug 12, 2003 | 03:35 PM
Patches's Avatar
Patches
2.2K Ohm, 1/2 watt works. :cheers:
Old Aug 12, 2003 | 03:54 PM
VetteDrmr's Avatar
VetteDrmr
Really surprised it got that hot, I wonder, did you have the cable zip tied up out of the way, or could it have gotten close enough to the exhaust to overheat?
Or was the resistor too small size wise?
Have a good one,
Mike
Old Aug 13, 2003 | 03:35 PM
splinters's Avatar
splinters
Default Re: CAGS bypass failure (VetteDrmr)
Resistor seems to have been too small. It was sealed in the dielectirc filler. The resistor was melted with no visible damage on the outside.
Old Aug 13, 2003 | 05:40 PM
VetteDrmr's Avatar
VetteDrmr
Hmm. With the resistor totally encapsulated, no way to radiate heat except through the wiring. Hadn't thought of that one before.
Thanks for the update, and have a good one,
Mike
Old Aug 14, 2003 | 12:37 PM
FunDriver's Avatar
FunDriver
Veteran: Marine Corps
You need a 2.2 ohm and can get a package of five from Radio Shack for less than $2. That's what I did and it's been working great for three years.
Old Aug 14, 2003 | 06:07 PM
6 speed Sid's Avatar
6 speed Sid
Default Re: CAGS bypass failure (FunDriver)
That might be 2.2K ohms. Sid.
To CAGS bypass failure
