This message appeared yesterday at my clubs Track Day at Pocono Speedway. What happened was the nut that holds the valve stem and sensoe came loose in my hand after I had a flat in the garage area. Does this mean I damaged the sensor? Is there a unique part number for the drivers side rear sensor?
Is there a proceedure listed anywhere that you know of within the forum? My next question was going to be how does the system know the new sensor is in the left rear...
I FOUND THE PROCEEDURE
I'm just not sure where to place the magnet.
Thanks...
all four sensors are the same. the part # depends on what year your vette is.
the sensor may be ok. i would try to reprogram it first. if that fails then you might need to replace it.
just position it around the valve stem close to the wheel. be careful and don't bump your wheel. you just slightly move the magnet around until the horn beeps.
