Gounding Points????
Old Aug 13, 2003 | 11:31 AM
tocoman's Avatar
tocoman
Default Gounding Points????
Where are the grounding points on a 2003 coupe?
Old Aug 13, 2003 | 01:25 PM
davidfarmer's Avatar
davidfarmer
Default Re: Gounding Points???? (tocoman)
Old Aug 13, 2003 | 05:06 PM
tpocock's Avatar
tpocock
Default Re: Gounding Points???? (davidfarmer)
What page of the repair manual is this on?
I was trying to look this up last night and could not find it (not listed in the index)
Old Aug 13, 2003 | 05:26 PM
davidfarmer
Default Re: Gounding Points???? (tpocock)
I got it from an online source, not the manual. However, it should be in the manual. I just looked at "ground" in the index.
Old Aug 13, 2003 | 05:32 PM
larrysb's Avatar
larrysb
It's in the body electrical section, under ground distribution. You'll also find out what systems are grounded to what point, which makes troubleshooting a lot easier.
Old Aug 15, 2003 | 07:26 PM
Vinzvette's Avatar
Vinzvette
A little something to add. What point would be for the fogs and the AIR pump? It looks like 6 or 7.
Old Aug 15, 2003 | 07:30 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Nice post David. Thanks! :cheers:
Tom
Old Aug 16, 2003 | 01:35 AM
mapman's Avatar
mapman
Page 8-95 of the 2003 service manual has the ground locations. The service manual is an inexpensive tool if you are going to do anything beyond the simple tasks. Each connector is listed and you can determine the ground circuit location of the circuit in question.
To Gounding Points????
