BROKEN HOTCHKISS SOLID ENDLINK! More within...
Old Aug 14, 2003 | 03:54 AM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
Default BROKEN HOTCHKISS SOLID ENDLINK! More within...
Well folks, the car pictured in my sig is currently at ACI in Ohio for major cosmetic upgrades/paintwork and they noticed that my right front endlink is snapped! I have the Mallett front bar and the hotchkiss solid endlinks. I don't know if you have seen these endlinks but they make the stock ones look like puny hot wheels metal! Anyway, I do autocross drag race and road race at Gingerman raceway (first time for that) so would that do it? Also should the car be realigned now? I have the original alignment on the car but have changed to fikse 18 in all around on pilot sports so should I use z06 specs for the alignment? Why did this huge endlink snap? Will that cause damage to other areas of suspension if I was driving a lot with it that way and didn't know it?
:confused:
Old Aug 14, 2003 | 04:38 AM
NastyC5's Avatar
NastyC5
Default Re: BROKEN HOTCHKISS SOLID ENDLINK! More within... (AVETTE)
Are the end links old? I know Hotchkiss had some problems in the past with their old ones breaking. Their new ones are suppose to be a lot better. Contact them, maybe they will send you a new one ;)
Old Aug 14, 2003 | 06:10 AM
turboo2u's Avatar
turboo2u
Default Re: BROKEN HOTCHKISS SOLID ENDLINK! More within... (NastyC5)
When you say you have a "Mallet" front bar, are you referring to the "blue" bar they sell on their website? If so, that's the T-1 bar that's 38mm and quite heavy and thicker than the Hotchkiss front bar. You made need the T1 links ($90 from Ken fitchner's). I just ordered a pair but haven't used them yet. Good luck. :seeya :seeya :seeya
Old Aug 14, 2003 | 09:29 AM
LG Motorsports's Avatar
LG Motorsports
Premium Supporting Vendor
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
The end links have spacers that help them to move within their design limits for the misalignment. If the spacers are not installed correctly the rod ends will bind against the swaybar, and fatigue the metal. This will cause the rod end to eventually break.
If you race, or AutoX, you should run the suspension through its full travel to varify that you are not binding the link.
But in general, if you have the end too close to the sway bar, it will bind earlier. And in AutoX you are really laying the car into the corners, so your suspension will be closer to full extension.
LG
Old Aug 14, 2003 | 06:47 PM
ToplessTexan's Avatar
ToplessTexan
Default Re: BROKEN HOTCHKISS SOLID ENDLINK! More within... (LG Motorsports)
Completely off topic... :bb
Lou, I dig that sig pic. :)
Old Aug 14, 2003 | 07:08 PM
LG Motorsports
Default Re: BROKEN HOTCHKISS SOLID ENDLINK! More within... (ToplessTexan)
So do I!! :yesnod:
LG
Old Aug 15, 2003 | 06:35 AM
Rx7Rob's Avatar
Rx7Rob
YIKES! I got my T1's used. No spacers were included with the endlinks.
Anyone know the ID, OD, and length so I can cut a few? Are they the same front and back?
LG
Old Aug 15, 2003 | 06:47 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Default Re: BROKEN HOTCHKISS SOLID ENDLINK! More within... (Rx7Rob)
It's been a while since I installed my endlinks, but IIRC, the "spacers" are AN flat washers.
Old Aug 15, 2003 | 09:46 AM
Patches's Avatar
Patches
Well, here's what the Hotchkis endlink configuration looks like. This pic is from the Hotchkis installation file. Notice the black spacers directly next to the endlink.
Click on image to zoom
[Modified by Patches, 9:47 AM 8/15/2003]
Old Aug 15, 2003 | 09:52 AM
Richin Chicago's Avatar
Richin Chicago
:confused:
Tony,
How long have you had them? I remember this seemed to be a problem a few years back. I seem, to very vaugely, remember something about bad heat treating. But it was, at least, a year ago.
Old Aug 15, 2003 | 11:33 AM
AVETTE's Avatar
AVETTE
Default Re: BROKEN HOTCHKISS SOLID ENDLINK! More within... (Richin Chicago)
I have had them for several years, don't know if they were installed correctly or not, but I would assume so. Once I get the car back, I will send the snapped endlink to hotckiss which told me they would replace it for free, good customer service. Will check the other ones also. The bar is the mallett sway bar (not the blue bar) that was beefier than z51 but not to T1 specs, cheers and thanks for the install info...
Old Aug 15, 2003 | 11:59 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
So do I!! :yesnod:
LG
Awesome sig pic!! :eek:
vetterdstr :cheers:
[Modified by vetterdstr, 9:00 AM 8/15/2003]
Old Aug 15, 2003 | 07:09 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Re: BROKEN HOTCHKISS SOLID ENDLINK! More within... (vetterdstr)
I see coupes rule, that is the race car. :lol: :lol:
To BROKEN HOTCHKISS SOLID ENDLINK! More within...
