[HEAD STUDS] Proper torque procedure???
Cruise-In IV Veteran
Does anyone know the proper torque procedure for head studs. I am sure it is different then normal bolts, ie. 90 degree after so many ft. lbs.
Plus can someone verify a Fel-Pro 1041 gasket will work on a 4.125" bore? I have been told this but would like to verify.
Thanks! :seeya
Thanks! :seeya
I would expect to use the same torquing procedure. This will give you the proper clamping force while NOT yielding the bolts.
However, you should contact both manufacturers to confirm.
Thanks! :seeya
Thanks! :seeya
'97 C5 I don't have the packaging or instructions anymore. Can you email me a copy of yours? mrb23@bellsouth.net
Thanks guys! :cheers:
With ARP moly lube the large studs are tightened in 3 stages to 65# then the small ones are tightened to 22. Go to 75 and 25 if using oil. The studs themselves are tightened into the block just until they bottom.
