A4 Question
Old Aug 15, 2003 | 04:50 PM
add's Avatar
add
Default A4 Question
Is the A4 tranny a 4 speed with an overdrive or is it a 3 speed with an overdrive.
Thanks,
Old Aug 15, 2003 | 05:52 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
Default Re: A4 Question (add)
Technically, it is a 4-speed automatic transmission, with the 4th gear being the overdrive gear. (1st Gear: 3.059:1, 2nd Gear: 1.625:1, 3rd Gear: 1.000:1, 4th Gear: 0.696:1).
Old Aug 15, 2003 | 05:59 PM
Richin Chicago's Avatar
Richin Chicago
Thanks,
I believe it would be considered a 3 speed with with a variable ratio torque converter and a lock up feature. The transmission itself only has 3 gears? Somebody correct me if I am wrong?
Old Aug 15, 2003 | 06:26 PM
MC98's Avatar
MC98
Default Re: A4 Question (WhiteC5Vette)
:iagree:
Old Aug 15, 2003 | 07:45 PM
WhiteC5Vette
Default Re: A4 Question (Richin Chicago)
Thanks,
Ok, I'll correct you. :lol:
It is a 4-speed auto trans. It has four gears in the planetary system (ratios shown in previous post), and one reverse gear (ratio: 2.294:1), it also has a locking torque converter. However, overdrive is supplied through the 4th gear, not via the torque converter, and the TC will lock up in 3rd and/or 4th gear.
In D overdrive, the 3-4 gear clutch, 2-4 band and forward clutch are applied locking in fourth gear to allow for the overdrive gearing.
Old Aug 15, 2003 | 08:20 PM
Dave00C5's Avatar
Dave00C5
:iagree: :thumbs:
Old Aug 15, 2003 | 09:37 PM
Cirrus8's Avatar
Cirrus8
My A4 converter locks up at approx 43 mph in fourth gear with minimum throttle. When it does, the rpm drops approx 150 -200 rpm so it is like having a 5-speed auto. :D :D
To A4 Question
