Rear End Leak thoughts....
Old Aug 16, 2003 | 01:26 AM
vettatude's Avatar
vettatude
Default Rear End Leak thoughts....
I'm planning on replacing my left side o-rings tomorrow and was reviewing the service manual tonight. Perhaps the reason why the left side is infamous for leaking is because there is a mount point to the crossmember coming off that side cover. There is no mount point coming off the right side cover. Maybe there is extra stress or vibrations that cause these left side seals to leak after a period of time?? Hmm... stupid design if you ask me. :rolleyes:
Old Aug 16, 2003 | 03:22 AM
SHOWTIME!'s Avatar
SHOWTIME!
Default Re: Rear End Leak thoughts.... (vettatude)
:lurk:
Old Aug 16, 2003 | 03:39 AM
texasredc8's Avatar
texasredc8
The vibration damper is also on the left side.
Old Aug 16, 2003 | 04:14 AM
c5inphila's Avatar
c5inphila
Default Re: Rear End Leak thoughts.... (TexasRedZ06)
Six bolts on left side. Nine bolts on right side. Just the o ring won't do it , you must use a thin film of anaerobic gasket maker on the outer lip of the cover [where the bolts go through].
Old Aug 16, 2003 | 08:48 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
You are doing this yourself? How difficult is this and how long will it take?
Old Aug 16, 2003 | 10:50 AM
vettatude's Avatar
vettatude
Default Re: Rear End Leak thoughts.... (JeepTJ)
Beats me, I'll let you know when I'm done. Probably 3-4 hours total.
Old Aug 16, 2003 | 11:45 PM
vettatude's Avatar
vettatude
Well, all in all not too bad of a job with the right tools. I got the seals for free, $20 in lube, and $120 on new tools. :D
Here are a few pics:
You don't need no slide hammer :smash:
Old Aug 17, 2003 | 04:10 AM
SHOWTIME!'s Avatar
SHOWTIME!
WHAT SPECIAL TOOLS DID YOU NEED ? oops sorry caps....
Old Aug 17, 2003 | 08:19 AM
vettenuts's Avatar
vettenuts
Default Re: Rear End Leak thoughts.... (SHOWTIME!)
Great job!!!
Maybe you should write a tech tip with your photo's. :hurray:
Old Aug 17, 2003 | 10:14 AM
vettatude's Avatar
vettatude
The two tools that made this job easier were the air hammer with pickle forks and the pry bars. Separating the ball joint and tie rod was a 30 second job with the pickle fork and air hammer. Getting the half-shaft out of the case was a 45 second job with the right size pry bar. Other than that, standard sockets with various extentions and such did the job. When I put the side cover back on I used some anerobic sealer on the flat surfaces to help seal it up, I didn't want to just rely on the o-ring. Also used some liquid teflon sealer on all the bolts holding the cover on. I'll try to put something together for tech tips.
Bill
Old Aug 17, 2003 | 12:21 PM
white top's Avatar
white top
Thanks look forward to your write since this seems to be all too common a problem. A couple questions another forum member said it was not necessary to disconnect the lower tie rod & I noticed you removed the brake caliper was this also necessary. As an aside did you see want the shop manual tells you to remove to do this job.
TIA Jerry
To Rear End Leak thoughts....
