LS1 To LS6 PCV Conversion. Worth It??
Old Aug 16, 2003 | 05:12 AM
LIGHTNING's Avatar
LIGHTNING
Default LS1 To LS6 PCV Conversion. Worth It??
Is it worth the time & $$ to convert the LS1 PCV to the LS6 style set-up? From what I understand, the problem with the LS1 PCV is it forces oil along with the air into the intake manifold. The LS6 system pulls the pressure from the valley cover rather than the valve cover, thereby eliminating the problem.
Old Aug 16, 2003 | 03:07 PM
88sk's Avatar
88sk
Default Re: LS1 To LS6 PCV Conversion. Worth It?? (LIGHTNING)
was thinkin about doin the same ,what little oil Im losin seems to be leavin by the pcv.
Old Aug 17, 2003 | 03:46 AM
Coolvet's Avatar
Coolvet
It is not expensive to do this mod and makes damn good sense in my view.
Old Aug 17, 2003 | 07:01 AM
blktie8's Avatar
blktie8
I'm On the fence on this one ,I haven't heard if it is really a fix or not.
Jmx actually hasn't said anything that I know of .
I want to do it but wuold like to hear some positive results (or negitive)
John
Old Aug 17, 2003 | 07:46 AM
marco383's Avatar
marco383
Default Re: LS1 To LS6 PCV Conversion. Worth It?? (blktie8)
I did the conversion along with an in-line filter between the PCV valve nad throttle body. I still get a small amount of oil in the filter, so the LS6 system isn't perfection.
To LS1 To LS6 PCV Conversion. Worth It??
