Tire Pressure Queation
Aug 17, 2003 | 02:48 PM
I have a 99 coupe and I am wondering what tire pressure to run. I have Nitto's on the car and use it as my daily driver.
Thanks,
TD
Aug 17, 2003 | 03:48 PM
Re: Tire Pressure Queation (add)
30 cold. :thumbs:
Aug 17, 2003 | 05:07 PM
I like 31 cold. 30's OK too though. :thumbs:
Aug 17, 2003 | 06:08 PM
And it keeps going up. I run 32 cold on my daily driver. Got the Nitto's with 25k on them and still look and hook great. :yesnod:
Aug 17, 2003 | 11:20 PM
Re: Tire Pressure Queation (Old Rotor Head)
30 cold is what's generally recomended.
Aug 18, 2003 | 08:24 AM
I have the GY EMT's but I run 32 front and 28 rear. This gives me 100% even tire wear.
With 30/30 as recommended, the rears showed some cupping in the center and the fronts wore more at the edges. Nevertheless I still got 45K miles out of the runflats.
Roger
Aug 18, 2003 | 01:18 PM
When I get to 28 psi on my rear tires I get a "check Gages" alarm on my 2000 dash. That sensor is sure sensitive. I keep it at 30 psi cold.
Aug 18, 2003 | 06:55 PM
Re: Tire Pressure Queation (cortex)
Aug 18, 2003 | 11:03 PM
Re: Tire Pressure Queation (VETFVER)
Quote:
30 cold. :thumbs:
:iagree:
DITTO! :cheers:
Sep 1, 2003 | 09:11 PM
Re: Tire Pressure Queation (Fang S-289)
30 "cold" is not the same in summer and winter and can result in over or under inflation in the turns. I develped outside scalloping on my F1 Supercars and had a lot of squealing in the turns to explain it. Now I am running 34 front and 32 rear with less noise and hopefully less wear but it is a a bit of a harder ride.
