Re: SCM Code B0846 Battery 2 out of range? (tommyn)
DTC B0846 is th LH seat control module.
the manual states the problem is usually faulty wiring and connectors then the module itself.
i can't help you much on where to start.
it recommends using a scan tool to diagnose.
hopefully someone will jump in and point you in the right direction.
