Identity of Codes
Old Aug 19, 2003 | 11:51 PM
adios-1's Avatar
adios-1
Default Identity of Codes
Once you get into to code sequence how do you display the code? In other words, when the display shows "10-pcm 1 codes" "60-IPC 1 codes" "80- radio 3 codes" what do you do next to display the actual code? I should add that I hit the reset button and erased the above. Is it possible to retreive the data or must I wait until it shows a code again? All help is appreciated.
Old Aug 20, 2003 | 07:45 AM
THRAP 42's Avatar
THRAP 42
Default Re: Identity of Codes (adios-1)
Instructions on my website, as well as all the codes. http://corvetteforum.net/c5/thrap_42/
later,
