Do headers require a relearn ?
Old Aug 21, 2003 | 04:15 PM
redzone's Avatar
redzone
Default Do headers require a relearn ?
I'm having TPIS long tube headers installed next week & was told by the installer a relearn is not required. Other than the headers the only performance mods are blackwing & Borla Stingers.Anybody have any experience with this setup. I want the car to take as much advantage of this mod as possible. Also, what are your thoughts on the larger mass air sensor? thanks in advance! :cheers:
Old Aug 21, 2003 | 04:24 PM
blown in n.c.'s Avatar
blown in n.c.
Default Re: Do headers require a relearn ? (redzone)
Are you getting them put on at More? To maximize them an edit would be suggested, but there's no place around to dynotune a LS1.
Old Aug 21, 2003 | 05:02 PM
MiamiDave's Avatar
MiamiDave
Default Re: Do headers require a relearn ? (blown in n.c.)
:iagree:
Old Aug 21, 2003 | 05:14 PM
c5chris's Avatar
c5chris
You'll run rich following a LT header install. Idle relearn is not enough, so it is recommended to do tuning. LS1Edit or Predator with a wideband dyno seems to be the concensus.
To Do headers require a relearn ?
