Torque spec?
Old Aug 22, 2003 | 01:56 PM
slogan_98's Avatar
slogan_98
Default Torque spec?
Would someone be so kind as to give me the torque spec for the waterpump bolts?
Thanks ,
Steve
Old Aug 22, 2003 | 02:25 PM
THRAP 42's Avatar
THRAP 42
Default Re: Torque spec? (slogan_98)
Here you go,
Water Pump Bolt (First Pass)
15 N·m
11 lb ft
Water Pump Bolt (Final Pass)
30 N·m
22 lb ft
later,
Old Aug 22, 2003 | 02:26 PM
C4TOMCAT's Avatar
C4TOMCAT
water pump housing bolts= 11 lbft
water pump bolts (first pass)=11 lbft
water pump bolts (second pass)=22 lbft
water pump cover bolts = 11 lbft
Old Aug 22, 2003 | 03:06 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
How about the seat belts?
Old Aug 23, 2003 | 07:45 AM
slogan_98's Avatar
slogan_98
Thanks,
I really appreciate it.
Steve
Old Aug 28, 2003 | 12:14 PM
THRAP 42's Avatar
THRAP 42
Default Re: Torque spec? (Godspeed)
Godspeed,
Here you go;
Buckle Side Nut
50 N·m
37 lb ft
Child Restraint Tether Anchor Plate Bolt
27 N·m
20 lb ft
Lower Retractor Bolt
47 N·m
35 lb in
Shoulder Harness Guide Bracket Bolt
27 N·m
20 lb ft
Upper Guide Bolt (Coupe, Hardtop)
41 N·m
31 lb ft
Upper Guide Nut (Convertible)
40 N·m
29 lb ft
Upper Lock Pillar Trim Screw
1.8 N·m
16 lb in
Upper Retractor Bolt
41 N·m
31 lb ft
To Torque spec?
