With the mods i have in my sig. what's the best cam for my car, i will be adding stage II heads in the spring of 04. i will only be adding cam and tuning next week . which cam should i get????? looking for an xtra 40 rwhp.
The MTI X1 cam might get you close to 40rwhp on your A4. You may want to contact Lou at LGM an inquire about his G5X-2 cam. I know of one guy with stock heads and A4 who got a little over 400rwhp with bolt-ons.
Whatever you go with make sure you don't pick one too small...I made the mistake of worring about getting a cam too big...now the one I have is too small and I want a bigger one. If you are going to be going with a set of Stage II ported heads later on might as well pick a cam that is going to really make those heads shine...I believe LG's G5X-2 is putting out over 400rwhp with Stage II heads...
On an A4 I would go with a 224/224 561/561 or the same duration with 581/581 lift. This cam will give you great driveability and valve train reliability.
If the weather is decent you should run the 11s with no problem. Remember Edgar ran 11.4s "Cam Only".
If all else fails you can install a bad **** TCS4200 like yours truely :D
