HELP, check engine light......
Old Aug 24, 2003 | 11:45 AM
lawman34203's Avatar
lawman34203
St. Jude Donor '13-'14
Default HELP, check engine light......
My check engine light came on the other day. My car has a K&N Filter with a cut fan shroud. The light came on while I was driving in the rain. Could it be that I got water in the intake or is it something else? How can I get a "code" that I see people ask about whenever something goes wrong. I drove the car 300 miles since the light came on, everything seems ok, but the check engine light is still on.
*** I just did an IPC codes check and it showed me "P0410 HC" which from what I read so far says "air system B" Does anyone know what this means??
I also had Stingers put on not long ago, could that be a factor also?
[Modified by lawman34203, 12:06 PM 8/24/2003]
Old Aug 24, 2003 | 12:02 PM
TXNC5's Avatar
TXNC5
Default Re: HELP, check engine light...... (lawman34203)
You are correct. Check the codes, decide whether or not it is a problem, then erase the code. Here are some good directions and code descriptions:
http://www.corvettedoctor.com/1997-00_Codes.htm
I doubt if too much water in the intake is your problem. You would not have been able to drive it if that were the case.
Old Aug 24, 2003 | 12:17 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
The P0410 code is the secondary air injection system. This system is used to lower the tail pipe emissions during startup. Since this is a emissions item take it in for warranty repair.
Old Sep 1, 2003 | 11:08 AM
MikeP's Avatar
MikeP
Default Re: HELP, check engine light...... (TXNC5)
Can you tell me if the DIC codes for the 2001-2003 have changed that much from the 97-00 listing you post.
Thanks for your help
Mike P :cool: :thumbs:
To HELP, check engine light......
