Possible New column Lock Solution
Old Aug 26, 2003 | 03:24 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Possible New column Lock Solution
I got my actuator replaced at the dealer 2 months ago, and all was well. I was driving the other day and saw my voltage dropping. So I took it to the dealer, under warranty, and the car was at 10.1 volts by the time I got it there. The traction control, and service engine soon light came on. When I got to the dealer, the dealer turned off the car, since they wouldn't get to it for a while.
When the dealer wanted to start the car, the column lock wouldn't disengage. Dealer charged the battery overnight, and finds that 3 wires on the BCM were cut/ crimped. This threw 3 BCM codes. So if your column lock is acting up... it maybe your BCM.
Old Aug 26, 2003 | 08:07 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
Default Re: Possible New column Lock Solution (ICULUKN-C5)
If the column lock actuator does not get sufficient voltage,it can confuse the BCM and cause the column lock not to function :yesnod: Just one more reason that as long as there are column locks,there will be column lock faults :steering:
Old Aug 26, 2003 | 09:06 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
:lurk:
Old Aug 26, 2003 | 09:17 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: Possible New column Lock Solution (AC54ME)
I got BIT by the Column lock bug on Friday while I was at the Carslile Event washing my car at the car wash area!!!
I took the cover off of the steering column and proded and poked the steering column wiring harness. After that it worked fine for the test of the weekend.
Damn thing has got to get the by-pass fix SOON!!!!!!!!!!!!!!!!!!!
Old Aug 26, 2003 | 09:57 PM
Colorado Chuck's Avatar
Colorado Chuck
Never had a problem with mine, but after hearing a lot of horror stories I installed the column lock bypass sold by a Forum Member. Installed easily and works just great. Cheap, too.
See it at LS1howto.com
To Possible New column Lock Solution
