Lowering the rear end.
Old Aug 28, 2003 | 01:40 PM
JasonZ28's Avatar
JasonZ28
Default Lowering the rear end.
Is it possible to lower the rear without cutting the bushings? I have done the searches and they all say to cut them. I am not looking to go too low just about an inch. Sorry about another lowering thread, but thanks for the help in advance.
Jason
Old Aug 28, 2003 | 01:53 PM
Special K's Avatar
Special K
Default Re: Lowering the rear end. (JasonZ28)
Somebody will jump in here that knows what they're doing. I've read you can drop an inch without cutting.
Bob
:flag
Old Aug 28, 2003 | 02:19 PM
Kaley@DragonRace's Avatar
0Kaley@DragonRace
Supporting Vendor
Default Re: Lowering the rear end. (Korreck)
You can. It is really easy to do. I noticed that you live in Colorado. If you need some help I can help you out. kaley
Old Aug 29, 2003 | 12:06 AM
corvette dave's Avatar
corvette dave
Jason,
The rear is very easy to lower and most C5's get about 1".
If you want more, get longer bolts.
Do not ever cut the rear bushings!
Dave
Old Aug 29, 2003 | 12:10 AM
corvette184's Avatar
corvette184
Default Re: Lowering the rear end. (corvette dave)
:iagree: :iagree: see pic below....no cutting ..just turn the wrench
Old Aug 29, 2003 | 12:17 AM
JakeL's Avatar
JakeL
Default Re: Lowering the rear end. (corvette184)
As the others said - easy as turning the bolts.
my Konis jacked up the back a bit due to their higher gas pressure, so I installed longer bolts from Andy @ A&A. Took about 20 minutes start to finish, easy as pie.
C5only21 - sent you an IM - looks like we're both in Ft. C.
Cheers!
-Jake
To Lowering the rear end.
