Cutting Shifter
Old Aug 28, 2003 | 07:18 PM
Silver99's Avatar
Silver99
Default Cutting Shifter
I am looking at cutting a half inch off my stock shifter handle and want to thread a nut on there first to chase the threads after cutting. Does anyone know what size nut I need and where to get it?
Old Aug 28, 2003 | 07:27 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Cutting Shifter (Silver99)
9/16"-18
Available at any local hardware store.
But unless your shift **** is bottoming out on the threads, just cutting threads won't change the **** height, it will only lessen the number of threads in the shift ****.
If you can see threads below the **** with it screwed all the way down, then you will shorten it.
:cheers:
[Modified by Y2Kvert4me, 6:27 PM 8/28/2003]
