Vapor Lock ?
Old Aug 27, 2003 | 09:29 AM
Nixs99's Avatar
Nixs99
Default Vapor Lock ?
Here is my problem. I have a 99 vette with 47000 on it the only mods I have is a Corsa exhaust and a Blackwing filter. I have no x-pipe. I drive 30 miles to work and then 30 miles back. In the morning the car runs great. When I go home I hit about 15 minutes of bumper to bumper traffic but still no problems. The car does not run hot. I then park in my garage when I get home. After about an hour or so if I take the car back out, the car will hesitate, stall and even die out. I do not get a check engine light and no codes. I check the fuel pressure and still shows about 58 lbs when the car is acting up. The engine compartment is still very hot. It appears to be some sort of vapor lock, the car only does this after it sits when I come home from work after about 45 minor an hour. I even wiggle the fuel line coming off of the fire wall, its hot. and the car will hesitate. I have no idea what the problem is. When the car cools off completely I have no problem. :confused: Thanks for taking the time to read this. Has anyone ever had this type of problem. Thanks Nick
Old Aug 27, 2003 | 11:05 AM
Special K's Avatar
Special K
Default Re: Vapor Lock ? (Nixs99)
I've not had this problem but you have to eliminate potential causes one step at a time. Try parking out side with the hood up when you get home and go from there. The fans may be shutting off too early causing a vapor lock. Through the process of elimination you'll find the problem.
Bob
:flag
Old Aug 27, 2003 | 01:53 PM
JonV's Avatar
JonV
Had almost EXACTLY this trouble with an old Toyota Tercel. Turned out it was the Engine Coolant Temp Sensor, the one that tells the PCM how to fuel the engine. Sensor bad, bad fueling, stall, run bad. It was so bad that I could almost predict where on my route home from work it would act up. Might be worth a look.
Old Aug 27, 2003 | 03:24 PM
SFVetteman's Avatar
SFVetteman
Default Re: Vapor Lock ? (JonV)
:iagree: The Engine Coolant Temperature Sensor (ECT) is a heat sensitive resistor (thermistor) that changes value based on temperature. If it is way out of range or just plain doesn't work, the PCM in the C5 will pick it up and throw a code. However, if just shifts values and stays within the range that the PCM expects to see then you get no codes but because it is false info then you get driveabilty issues including what you describe. There is also an ECT circuit associated with the ECT sensor that could be at fault but most likely just replacing the ECT sensor will cure the problem.
Old Aug 27, 2003 | 07:17 PM
Richin Chicago's Avatar
Richin Chicago
Nick,
I could be wrong but AFAIK vapor lock is almost impossible with the fuel delivery pressures of today's engines. Also I don't know where the vapor lock could even occur. My guess is that a sensor is giving the PCM some wrong information.
Old Aug 27, 2003 | 08:16 PM
DocSandy's Avatar
DocSandy
From: When I say who is the mastah you gotsta say Shonuf
Not a day goes by where I don't read some comparison of the C5 to the Tercel. :lol:
Old Aug 28, 2003 | 12:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NIXS99
I doubt if your high pressure fuel system is vapor locking. The high pressure keep the fuel from boiling off when the fuel line gets hot. You may have a secondary ignition problem. See if you have spark at the spark plugs when you expierence the problem. If you do not see any codes, you could have an ignition coil power problem.
Bill C
Old Aug 28, 2003 | 12:56 AM
66ImpalaLT1's Avatar
66ImpalaLT1
Default Re: Vapor Lock ? (Bill Curlee)
You cannot vapor lock a fuel system with an in-tank pump. Thats one of the reasons I had a custom tank made for my '66.
Eric
Old Aug 28, 2003 | 07:45 PM
Bob Chapman's Avatar
Bob Chapman
Default Re: Vapor Lock ? (DocSandy)
Good one Doc
To Vapor Lock ?
