I have Jesel 1:8's that increased the lift .060 over stock, so 1:85 may be .075 or greater. However they are in conjunction with a cam so can't comment on perf of those only. Note we had to grind clearance in the valve covers to clear the 1:8's. Jesel's were $700.
Fred K.
Has anyone installed a set? Is the perf. increase worth the expense? Seems like a nice way around a cam swap for a modest lift change.
I had the cranes with stock and they were a great improvement. You can't use them without a spring swap tho and now you are looking at more $$$. The cam would be a much better bang for the buck. If you do the work yourself it is way cheaper for the cam and you will get far more than the 12-15hp from the rockers.
If you do go this route.....don't use the SLP ones...comp cams and yella terra have full roller rockers in these ratios so you can reduce friction and get some better protection from the dredded rooler-pin-in-the-motor issue.
The only justification for higher ratio roller rockers is if one fits all of the following categories:
1.) You have a belt-driven supercharger on an otherwise completely stock engine and it makes peak power at 6000 rpm or higher but the fuel cut is at 6200 rpm (for LS1s). But you need to shift at 5%-15% above your power peak rpm to fully translate the dyno numbers to track numbers and hence...
2.) You decide to change valvesprings and pushrods to raise the rev ceiling so you can shift at appropriate rpms
If you satisfy both criteria, then for the same labor as changing valvesprings, you could and might as well change the rockers to a higher ratio. You will likely get 10 to 18 extra flywheel hp plus you'll keep stock drivability.
The YTs are only available as 1.7 amd 1.8, not 1.85.
