Base to Z51 spring change?
Old Aug 30, 2003 | 10:17 PM
98silverC5's Avatar
98silverC5
Default Base to Z51 spring change?
I am considering changing my base suspension to the Z51 suspension. I know changing shocks and sway bars are easy but was wondering how hard it is to change the springs and is it worth it? Thanks
Old Aug 31, 2003 | 08:02 PM
98silverC5's Avatar
98silverC5
Default Re: Base to Z51 spring change? (98silverC5)
anyone?
Old Aug 31, 2003 | 09:43 PM
see5's Avatar
see5
I started with Z51 and went Z06. If I were you I would skip Z51
Old Sep 1, 2003 | 01:57 AM
TGrits10's Avatar
TGrits10
Default Re: Base to Z51 spring change? (see5)
Then you'd know how much trouble changing springs is. Please provide teh info, I'd like to know as well :yesnod:
I'm thinking about swapping in either Z51 or Z06 springs on my selective ride control softie.
Old Sep 1, 2003 | 02:56 AM
jmX's Avatar
jmX
Default Re: Base to Z51 spring change? (TGrits10)
A spring change is pretty easy, I documented it here: http://www.ls1howto.com/index.php?article=20
:cheers:
Jon
Old Sep 1, 2003 | 08:14 AM
98silverC5's Avatar
98silverC5
Thanks for the info, it looks easier than I thought. :seeya
Old Sep 1, 2003 | 09:45 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Default Re: Base to Z51 spring change? (jmX)
jimx: Once again your site provides excellent instructions. I'm not sure if I'll do this myself or not, but I may go from FE1 to FE3 springs since I've already done the sway bars and Bilsteins. :cheers:
To Base to Z51 spring change?
