Gears and a Converter
Old Aug 30, 2003 | 11:34 PM
hogurt's Avatar
hogurt
Default Gears and a Converter
I have a PT2900 and 3.42 gears. If I swap the 3.42's for 3.73's will my trap speeds increase?
Unfortunately, I never took the car to the track before modifying it and I am not certain how much of a difference my gears and coverter actually make?
Old Aug 31, 2003 | 12:18 AM
Mitch C's Avatar
Mitch C
Default Re: Gears and a Converter (hogurt)
All else being equal you should pickup 1-2 tenths by swapping 3.42s for 3.73s.
Old Aug 31, 2003 | 02:00 AM
hogurt's Avatar
hogurt
Default Re: Gears and a Converter (Mitch C)
Yes, I understand I will improve my times. . .however, I am specifically wondering if the change in gears will result in a higher MPH? :cheers:
Old Aug 31, 2003 | 02:23 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
It depends upon shift points. You will need a little tuning.The 3.42 gear is a good all around gear.I would change out that converter and go with a yank ST 3500.
:thumbs: :iagree:
Old Aug 31, 2003 | 03:22 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Gears and a Converter (LittleBoyBlu99)
super thruster 3500 are bad azz....................
Old Aug 31, 2003 | 03:50 AM
Mitch C's Avatar
Mitch C
I would say you will gain 1-2 MPH. I agree the Yank ST3500 or better yet the SS3800 will give you better ETs and higher MPH. :cheers:
Old Aug 31, 2003 | 08:32 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
I'll be surprised if you pick up any trap speed with just the gear swap. Unless you're well out of your power band in the traps now (I doubt you are) it shouldn't make too much difference (i.e. allow you to reach your power band better in 3rd within 1/4.) I think I saw maybe +1.5 MPH when swapping from stock TC+3.15 to SY3500+3.73, most of which I attributed to the converter.
To Gears and a Converter
