Need some help - P0343 CMP Sensor Circuit High Voltage -B
Old Aug 31, 2003 | 12:29 PM
bravo787's Avatar
bravo787
5th Gear
Default Need some help - P0343 CMP Sensor Circuit High Voltage -B
Check Engine light came on in my 99 hard top - code readout is P0343 CMP Sensor Circuit High Voltage -B - After I cleared the code, i turned the key to the first position, and the code comes up before starting the car - and the car is hard to start if it is cold.
I think it is the Camshaft Position Sensor - either a loose wire or bad sensor - has anyone had a similiar problem? And where is the sensor located on the engine?
Any help would be great. Thanks
