Forged Internals/piston ring question
Old Sep 1, 2003 | 02:05 PM
SpinMonster's Avatar
SpinMonster
Default Forged Internals/piston ring question
I am going with Diamond pistons .......... any opinions on their piston rings or a suggestion of a better ring if there is one.
Old Sep 8, 2003 | 07:17 AM
SpinMonster
Default Re: Forged Internals/piston ring question (SpinMonster)
file-fits?....anyone?....I should have titled this.....1/4 mile times inside... :skep:
Old Sep 8, 2003 | 09:16 AM
Phil97SVT's Avatar
Phil97SVT
Guy,
I would go with the Diamond rings again. I have heard only good things about them. Ring gaps: .016 .020 gaps
Phillip
Old Sep 9, 2003 | 03:22 AM
SpinMonster
Default Re: Forged Internals/piston ring question (Phil97SVT)
did you have them filed to fit the stock bore?
Old Sep 9, 2003 | 03:31 AM
blu00rdstr's Avatar
blu00rdstr
I assembled the Diamond pistons and file-fit rings just last week. I went with Diamonds because of the -8.6 dish, but had to use 6.125" version with 6.125" rods (Eagle H-rods).
3.905" bore, cylinders were honed to fit. Eagle rods, small ends were honed to fit piston pins.
Spiral retaining clips are difficult at first, stretch them to a 1/4" long coil first.
Rings (Blower app) were filed to .018" and .020". Make sure you check frequently with smaller feeler gauges to track progress, otherwise the go/no-go technique will cause you to go beyond target gap.
If you have the moving parts balanced, bring the rings and bearings so the right bob weights can be set.
To Forged Internals/piston ring question
