does lowering reduce traction
Old Sep 2, 2003 | 11:05 PM
master blaster's Avatar
master blaster
Default does lowering reduce traction
a guy with a zo6 said his 1.60 60 droped to 2.0 after lowering. he said my vert has softer springs so it may not hurt me as much. what do you think?
Old Sep 2, 2003 | 11:10 PM
427CPE's Avatar
427CPE
Default Re: does lowering reduce traction (master blaster)
You lower the car, the suspension gets stiffer. It doesn't necessarily handle better and certainly a stiff car is going to blow the tires quicker. A DRAG car needs to be able to load the tire, therefore a stiffer suspension will induce even less flex in the suspension and viola, you'll blow the tires easier.
Also, I would wonder what mucking up the camber will do to traction as well from lowering.
Old Sep 2, 2003 | 11:15 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Certainly possible.
While you aren't changing the spring rate by lowering, you are lessening the the amount of suspension travel. When you launch hard, the rear end squats down, and this weight transfer is a big factor in traction. If you really slam the car (particularily the rear), you are reducing that amount of "squat" and weight transfer, and thus lessening launch traction.
:cheers:
Old Sep 3, 2003 | 04:25 AM
cmeflyby's Avatar
cmeflyby
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
Default Re: does lowering reduce traction (Y2Kvert4me)
did he get it aligned after lowering???
many people don't bother but if you want the best rear wheel traction for straight line or lateral handling you must realign. by lowering it you change the suspension geometry and the tire loses contact patch area as camber increases. you get the contact patch back by realigning and getting the tire tread back in full contact with the ground.
Old Sep 3, 2003 | 11:14 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
This is possible as the Z06 already has a fairly stiff suspension and will definitely affect weight transfer.
I have a lowered 99 coupe running the F1 Supercars on Z06 repros. I had an alignment done to Z06 specs to take advantage of the negative camber.
One can also temporarily unbolt the front sway bar at the track to help with weight transfer.
I have the F45 suspension option and I have it set to tour while racing in a straight line.
:cheers:
To does lowering reduce traction
