Help, Car wount start Error code U1160, U1176
Old Sep 3, 2003 | 10:55 AM
Blacked-out's Avatar
Blacked-out
Default Help, Car wount start Error code U1160, U1176
got these codes, does anyone know what they are , and how to fix?
Did a search what the heck is a RFA and DDM? :banghead: :banghead:
Car wount start, battery has 14V, car wount even turn over.
Old Sep 3, 2003 | 11:25 AM
ToplessSpiral's Avatar
ToplessSpiral
Default Re: Help, Car wount start Error code U1160, U1176 (black_c-5)
TRY http://WWW.C5FORUM.COM/AYC/DTCDIC.PHP
Good Luck :chevy
Old Sep 3, 2003 | 12:30 PM
mapman's Avatar
mapman
Did a search what the heck is a RFA and DDM? ... Car won't start, battery has 14V, car won't even turn over.
The U1160 and U1176 codes respectively refer to serial data link communication problems with the Driver Door Module (DDM) and the Remote Control Door Lock Receiver (RCDLR). RFA refers to Remote Function Actuation, like your door locks or tire sensors.
It might be that these communication problems are being interpreted by the Body Control Module (BCM) as a vehicle theft attempt. The BMC can disable the starter, etc. Just a guess. Would probably require access to a scan tool to resolve. Corosion, loose connectors, damaged wiring harness, or damaged modules could cause these communication faults. Sounds like the starter is being disabled on purpose (as opposed to a starter problem). The first step would be to resolve the communication problem(s).
Old Sep 3, 2003 | 12:37 PM
sammylvr's Avatar
sammylvr
Default Re: Help, Car wount start Error code U1160, U1176 (mapman)
Just a thought. Would disconnecting the Battery for awhile reset things???
:grouphug:
Old Sep 3, 2003 | 12:43 PM
wwashing's Avatar
wwashing
Those are incidental communications errors. They appear in all car's memory. You may disregard them.
Check your battery connections. Do you have a Delco? Has it leaked? Your battery could be bad in spite of the 14V, how did you accertain that reading? :cheers:
Old Sep 3, 2003 | 12:56 PM
Blacked-out
Default Re: Help, Car wount start Error code U1160, U1176 (wwashing)
a fellow tuner suggested I get a scan tool. I just readthe codes from the dash. He said I probably have a 1255 which is a communication error...so all I have to do is check the connections, all 4,642 of them :)
I replaced the battery 4 mo ago.....Ill try swapping batteries with my truck. I used a voltometer to get the 13.9 reading
[Modified by black_c-5, 12:32 PM 9/3/2003]
Old Sep 3, 2003 | 02:14 PM
Bill Dearborn's Avatar
Bill Dearborn
Check your key. It sounds like you have a VATS problem. Do the dash lights and instruments all work properly when you turn the key to start? Make sure the pill is not wet, dirty or missing. If you have an intermittent problem you will need to wait 4 to 5 minutes before you can try starting the car again. If you wait less time you will reset the system timer back to maximum delay. VATS disables, spark, fuel, and starter when the wrong key or a dirty/wet key is used and will not permit another start attempt until the timer runs down.
Bill
Old Sep 3, 2003 | 03:04 PM
Blacked-out
Default Re: Help, Car wount start Error code U1160, U1176 (C5inNY)
I assume the pill is the little metal piece on the key. Come to think of it I am using my wifes keys (she went to work with my keys) I ll try my "primary keys when she gets home. Yes, everything works dash lights , driving lights, but the starter doesnt even engage. I also get a "service engine soon, low fuel...etc"
Thanks to all for the suggestions! Hope this works!
[Modified by black_c-5, 2:15 PM 9/3/2003]
Old Sep 8, 2003 | 11:40 AM
Blacked-out
took it to the dealer...BCM burnt out---$700...........ouch!
Thanks for all your help...I would've felt funny if it was just a fuse or a bad key!
Old Sep 18, 2003 | 05:26 PM
abraham's Avatar
abraham
whats the bcm? Did your car just click when you tried to start it?
Old Sep 18, 2003 | 05:34 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Sorry to hear that but glad you got it fixed :cheers:
BTW: BCM stands for body control module
To Help, Car wount start Error code U1160, U1176
